VOIP call rings, user answers but no sound
Jun 26th, 2009
I have set up VOIP between to sites.
Each site connects from a PBX to router then accross the WAN.
Site A calls site B, phone rings, user answers but there is no sound at either end!!! complete silence.
Can anyone help
Thanks in advance
Prathyush Keeriyatt Mon, 06/29/2009 - 09:25
No way audio occurs due to the following reasons:
- NAT, PAT and firewalls blocking UDP traffic exist b/w the endpoints.
- Troubles in IP connectivity.
Please check these and revert
franpena2008 Thu, 02/17/2011 - 23:47
I do not see firewalls denying udp traffic in the firewalls
Ip connectiviy is seems to be OK. I can ping ip phones from the gateway.
Signaling between ip phones and DECT phones is also OK but cannot hear voice.
10.161.101.248 is the gateway and 10.241.7.24 remote ip phone.
F10R248#sh voip rtp connections
VoIP RTP active connections :
No. CallId     dstCallId  LocalRTP RmtRTP LocalIP                                RemoteIP
10  153541     153540     16388    25520  10.161.101.248                         10.241.7.24
F10R248# sh log | i 10.241.7.24
Feb 17 10:22:53.196: voip_rtp_create_session: callID=151269, dstCallID=151268 laddr=10.161.101.248, lport=16446,raddr=10.241.7.24, rport=27792, type=3, sig_tos=3, ip_tos=5
Feb 17 10:22:53.216: RTP(15494): ps rx s=10.241.7.24(27792), d=10.161.101.248(16446), pt=18, ts=C60800, ssrc=963B6251, marker=1
Feb 17 10:22:53.228: RTP(9961): fs tx s=10.161.101.248(16446), d=10.241.7.24(27792), pt=96, ts=9EA4A8BD, ssrc=174E65F8, marker=1
Feb 17 10:22:53.236: RTP(15495): fs rx s=10.241.7.24(27792), d=10.161.101.248(16446), pt=18, ts=C608A0, ssrc=963B6251, marker=0
Feb 17 10:22:53.252: RTP(9962): fs tx s=10.161.101.248(16446), d=10.241.7.24(27792), pt=96, ts=9EA4A95D, ssrc=174E65F8, marker=0
Feb 17 10:22:53.256: RTP(15496): fs rx s=10.241.7.24(27792), d=10.161.101.248(16446), pt=18, ts=C60940, ssrc=963B6251, marker=0
Feb 17 10:22:53.272: RTP(9963): fs tx s=10.161.101.248(16446), d=10.241.7.24(27792), pt=96, ts=9EA4A9FD, ssrc=174E65F8, marker=0
Feb 17 10:22:53.276: RTP(15497): fs rx s=10.241.7.24(27792), d=10.161.101.248(16446), pt=18, ts=C609E0, ssrc=963B6251, marker=0
Ming Yuan Chiu Tue, 03/01/2011 - 13:46
Can you post configuration on the switchport for the phone that it is connected to and also post snippet of the voice configuration on the router.
