Link Aggregation
Jun 27th, 2009
Has any one experienced deploying link aggregation between a Cisco 6509 and a Marconi BXR-5000 using 1Gig interfaces? I know they only way I can do this on Cisco devices is by using port-channel, but other venders do not support port-channel.
Reza
Giuseppe Larosa Sat, 06/27/2009 - 08:12
Hello Reza,
in multi vendor context look for LACP support IEEE 802.3AD other vendors can give to this other names.
on cisco side you need to use
channel-group x mode active
LACP message frames are exchanged on each member link providing also a protection mechanism.
if a port misses to receive LACP frames it is put in down state.
Hope to help
Giuseppe
