06-27-2009 01:04 PM - edited 03-21-2019 01:15 AM
I just change my UC520 lamguage to french, but french prompt like BusinessOpen.wav, BusinessClosed.wav are not available. Where can I download them ?
Solved! Go to Solution.
06-29-2009 06:39 AM
Do you mean you are still hearing the English prompts after localizing to French?
Marcos
06-29-2009 06:39 AM
Marcos
06-29-2009 06:47 AM
no nothing. I suppose to copy them before localizing. I have any prompt in the system now.
06-29-2009 07:02 AM
OK, I think you mean that you don't hear anything??
Did you follow this procedure:
https://supportforums.cisco.com/docs/DOC-9692
The above is for CCA 1.9, but the steps should be similar if you are using 2.0.
Marcos
06-29-2009 07:09 AM
I followed this document, but didn't do step 2, that why I lost the prompt (AABusinessOpen.wav, AABusinessClosed.wav......)
