High processor utilisation on 6509 cat os
Jun 27th, 2009
Please, I have a 6509 running cat OS..my process is running up to 80%..
1.What is the max advisable
2.Could this be more of routing than switching ?
3.What command do I issue on 6509 at the switching plane, to see the proc usage.
Giuseppe Larosa Sun, 06/28/2009 - 02:38
  • Hall of Fame,
    Founding Member
Hello Just,
a troubled day yours but this could explain also the other issue (the OSPF one).
1) a C6500 is expected to work between 10-30% cpu under heavy load traffic (not in a lab)
2) if this is a lab the issue can be caused by STP problems
also if it is in hybrid mode and you refer to supervisor cpu usage clearly it cannot be caused by routing issues.
see this link to troubleshoot high cpu usage
http://cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a00804916e0.shtml#utilities
Hope to help
Giuseppe
Just Kennie Mon, 06/29/2009 - 22:24
The STP has not been altered for a long while. Also how will I troubleshoot the STP. If there is loop and broadcast on my network pls how can I troubleshoot it.
