help my in router
Jun 27th, 2009
i have my DHCP server connect to switch 6500 and generate a lot of vlans from this switch in RSM (MSFC2) im my department our vlan is vlan 5
witch the ip is 10.2.41.X i have other
branch in the same city i used privet network (PLL) and one router in both site
site A and site B the DHCP server in Site A i want Site B take the same ip of our vlan 5 10.2.41.X form DHCP or static but same Vlan 5
"if any one need drawing to help my i will post the network drawing)
Overall Rating: 1 (1 ratings)
pompeychimes Sun, 06/28/2009 - 07:46
  • Bronze, 100 points or more
Not after that rating. I'm sorry, but what you said didn't make any sense to me.
I'll resist the temptation to rate your post poorly.
Tony.henry Thu, 07/09/2009 - 13:36
enqbandar,
I think you should provide a drawing. just to clear the question up a little.
From what I can understand here, you've got two sites, one with lots of vlans and the other with not so many. you want the other site to be in the same broadcast domain as one of your subnets from the first site?
Am I assuming correctly?
Tony
Rick Morris Fri, 07/10/2009 - 07:56
  • Silver, 250 points or more
This is a very hard post to understand. It is not clear what you want to accomplish and what you have in place today to make it work. It appears that you want site a and site b to have one dhcp server.
How are the sites connected? Is there a vpn between sites? How do you route traffic today between sites?
markliceralde Wed, 06/26/2013 - 18:03
You should consider the connection between Site B and Site A. how is it connected? In my understanding there is a router in between site A and B? in that case you could use VTP to propagate the VLAN  from Site A to Site B. and please post the Drawing. so we could understand it clearly.
Paolo Bevilacqua Wed, 06/26/2013 - 22:02
  • Hall of Fame,
    Founding Member
You are responding to a 4 years old post with even some bitterness in it. Hopefully by now people has moved on.
markliceralde Wed, 06/26/2013 - 22:54
Sorry when I replied I didin't check the Date. My bad. yeah sadly there was bitterness invloved.
Mark
