Firewall Active/Standby connection to Dual Core Inside network
Jun 27th, 2009
I have dual core L3 Switches (4503-E) in LAN. I want to connected this Core network as Inside to Active/Failover setup. Then to connect Firewall cluster to internet through a 2821 router
Can anyboby elaborate what is the best way to achieve this. I want to do NAT in firewalls. I have only 6 public IP addresses for LAN segent.I want to eliminate single point of failure for connection from dual core to firewall cluster
regards,
Waruna
Overall Rating: 5 (1 ratings)
