Cisco Unity Express Upgrade 7.0.1
Jun 27th, 2009
Dear All,
I m trying to upgrade my unity express from 3.1 to 7.0.1...but i receive the below error message....
Downloading ftp cue-vm-k9.nm-aim.7.0.1.pkg
Download error
Can not download cue-vm-k9.nm-aim.7.0.1.pkg error code 530 error type 'Access d
enied: 530'
cue#
what can be possible task i should do to resolve this issue...
Malik.
1ashlee2794 Sun, 06/28/2009 - 22:59
Can you verify that you have good connectivity to the ftp server?
Cheers,
ash
jleon22 Mon, 06/29/2009 - 11:44
  • Bronze, 100 points or more
Do you have the ftp credential parameters set up correctly?
You can use this upgrade/install guide as reference:
http://tinyurl.com/mdw7ko
tiger_401 Fri, 07/03/2009 - 23:58
Dear Jleon,
I was trying to upgrade my unity using the pdf link u send. But i m facing the below problem. Can you plz help me in this regard.
cue# software download status
Download request did not complete successfully.
File retrieval error. Please verify if file is on the server.
Error transferring file : ftp download failed cue-vm-en_US-langpack.nm-aim.7.0.1
.prt1 code: 19 reason:
cue#
Malik.
