Scott Fella Sun, 06/28/2009 - 06:39
That shouldn't happen. On the CLI, do a show run-config not a show running-config and attach that to the post. There might be an issue with your configuration.
Scott Fella Sun, 06/28/2009 - 19:31
Well I see you are using the 6.x.... pretty new. 4.2.130 & 4.2.205 seem pretty stable to me, but in your case,I would at least install the 5.2.157.0 ER image. The configuration looks fine. Have you had a previous code prior to moving to the 6.x, if so, did you have the issue you are having with the 6.x?
afernandez0226 Sun, 06/28/2009 - 19:56
Thanks for the reply.
After I received the wlc; i upgraded to 6.x before I started the configuration; I never used the configuration that came with it. Should I downgrade to 5.2.157?
Scott Fella Sun, 06/28/2009 - 20:07
You could open a TAC case if you want to see if that is an issue with 6.x or not. If you plan on downgrading, then I would go with 4.2.205. 5.x isn't a very stable code.
afernandez0226 Sun, 06/28/2009 - 20:25
thanks at lot for your help. I will open a TAC case, and post back the soluction.
Leo Laohoo Sun, 06/28/2009 - 20:22
If you disconnect any one of your APs, the entire WLAN goes down or all the AP's go offline?
Have you tried the basic setup and build it up from there?
Trending Topics - Security & Network
