Giuseppe Larosa Sun, 06/28/2009 - 12:48
  • Hall of Fame,
    Founding Member
Hello Waseemullah,
I guess you would like to use SSO or RPR with these two supervisors mounted on the same chassis but you can't because they are of different models.
The best move is to get one additional Sup720-3B and to build the chassis with them.
Otherwise you could try to transform the sup720-3B in a 3BXL upgrading both the RP memory and the SP memory using two 1 GB chips.
But I'm afraid this is not enough to have the sup720-3B to think it is a 720-3BXL this should be written in some eeprom.
Hope to help
Giuseppe
waseemullahmemon Mon, 06/29/2009 - 05:36
hi giuseppe,
I really appreciate the response, we also concluded the same thing bz once we tried to bring up the chassis with only 3BXL it was working fine, while along with SUP-3B it (3BXL) was was goin' on ROMMON mode.
Thanks again ....
stewartjs Fri, 08/21/2009 - 06:17
I have a 3B and a 3BXL that I would like to run in the same chassis. Has anyone verified if upgrading the RP & SP memory will allow SSO or RPR to work with these different models?
Giuseppe Larosa Fri, 08/21/2009 - 08:39
  • Hall of Fame,
    Founding Member
Hello Jeff,
even if it is possible to upgrade the memroy chips on both RP and SP and to upgrade to a PFC 3BXL this could be not enough.
The supervisor can have written in some eeprom that is a sup720 3B and if this information is exported in the redundancy messages exchanged with the other supervisor this could lead to a failure of SSO or RPR strategy.
This kind of information can be seen with sh inventory
NAME: "5", DESCR: "WS-SUP720-3B 2 ports Supervisor Engine 720 Rev. 5.4"
PID: WS-SUP720-3B , VID: V04, SN: SAL1132WU89
the following example is for a sup720 3BXL
NAME: "module 6", DESCR: "WS-SUP720-3BXL 2 ports Supervisor Engine 720 Rev. 5.2"
PID: WS-SUP720-3BXL , VID: V02, SN: SAL10467RED
We should know the implementation of the redundancy protocol that exist inside the chassis but it is likely that the part-id is exchanged.
if instead we are speaking of upgrading a standalone SUP 720 3B this is something that can be done.
Hope to help
Giuseppe
