Subrate T3/E3 Card In 2811 Router
Answered Question
Jun 28th, 2009
I have a 2811 router with a subrate T3/E3 installed in it. When I run a "sh hardware" it shows the card is present, yet a "sh int" does not appear to show it, not can I appear to configure it in any way. The IOS installed should support T3 cards from the research that I did. Is there something special I need to do to be able to configure the card?
Correct Answer by Richard Burts about 8 years 3 weeks ago
Brian
You do not mention what the card is so it is hard to be sure what the issue is. But many of the T3/E3 cards require using the command
card type
to define whether this is for T1 or E1 use. After this is configured then the interface is created and you can configure it. So give it a try with card type t3 and let us know what happens.
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Sun, 06/28/2009 - 10:49
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Brian
card type
Rick
bjberginz Mon, 06/29/2009 - 08:03
Thanks for the help, you were correct, the solution was to use the 'card type' command in global config mode. I now have a proper Serial interface I can configure.
Richard Burts Mon, 06/29/2009 - 08:08
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Brian
I am glad that my suggestion helped you to resolve your problem. Thank you for posting back to the forum indicating that you have solved the problem (and thanks for the rating). It makes the forum more useful when people can read about a problem and can know that they will read a response which did lead to solving the problem.
Rick
