can't ssh to Cisco ASA 5505
Jun 28th, 2009
Hi, I can't seem to ssh to my 5505, even though I think I have it setup properly. Below is part of the config, can someone tell me what is wrong?
access-list 101 extended permit ip 255.255.
access-list vpnclient extended permit ip 25
access-list nonat extended permit ip 255.25
access-list acl_in extended permit tcp any host eq 3389
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
ip local pool clients
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-524.bin
no asdm history enable
arp timeout 14400
global (outside) 1
nat (inside) 0 access-list nonat
nat (inside) 1
static (inside,outside) tcp interface 3389 3389 netmask 255.255.255
route outside 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
http server ena
http insideng, statistics or sta
no snmp-server location
no snmp-server contactHCP Relay Agent state,
snmp-server community asa
snmp-server enable traps snmp authentication linkup linkdown coldstart
disk0: Display information ab
snmp-server enable traps syslog
crypto ipsec transform-set national esp-3des esp-md5-hmac
dns-hosts Show DNS ho
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
hostname Sho
crypto dynamic-map national 20 set transform-set myset
crypto isakmp identity addressof Interface Descriptor Blocks
crypto isakmp enable outside
crypto isakmp p
encryption 3des
hash sha
group 2erface
lifetime 86400erface status i
crypto isakmp nat-traversal 20
telnet insideventory information for all slots
telnet timeout 5
ssh outsidensi
Platform ASA55
ssh timeout 5p
console timeout 0ss, IDS statistic
class-map inspection_defaultt.ecs (3316 bytes/sec)change
match default-inspection-traffic
Overall Rating: 4.8 (4 ratings)
Richard Burts Sun, 06/28/2009 - 10:20
I see that you have configured to permit ssh on the outside interface using this:
ssh outsidensi
but your post is not specific whether you are attempting SSH from an outside address to the outside interface or whether you are attempting SSH from an inside address to the inside interface. Perhaps you should also enable SSH on the inside interface.
Perhaps it would also help to configure authentication for SSH. It might look something like this:
user password
aaa authentication ssh console LOCAL
(note that LOCAL needs to be upper case).
mikejgalovich Sun, 06/28/2009 - 10:32
I know a Cisco guy who I want to give access to, but I can't because ssh won't work. I want him to review the setup and enable FTP too
Richard Burts Sun, 06/28/2009 - 10:45
The link that Toshi sent is a good one and it reminds me that you also need to generate RSA keys to enable SSH. You do not mention whether you have done this step or not. The command would be:
crypto key generate rsa modulus modulus_size
