11 digit dialplan need to be able to xfer 4 digit during Unity AA greeting
Jun 28th, 2009
We have an AA that allows for tranfering to an extension while the greeting is running. But the client wants to be able to dial 4 digit extensions during the AA greeting.
dial 4 digit extensions when they have 11 digits Dial plan.
How do I configure the call handler or unity to make this happen.
Currently all the users have an 11 digit dial plan. What will it take to get this done?
THanks
Overall Rating: 4 (1 ratings)
pgcristovam Sun, 06/28/2009 - 16:22
On cucm, configure Translation Pattern that translate xxxx to yyyyyyyxxxx
Thx
Peterson
j.low Mon, 06/29/2009 - 19:39
The best apporach is to modify the cue script to append missing numbers.
For example, CUE AA allow 3 digit numbers (130) transfer, to reach the Internal extension which is 8-664-24130, you have to append 866424 in cue script then.
I have attached an working example which you could refer to it.
shirwaziri1_2 Fri, 07/10/2009 - 12:58
sorry..should have specified, this is Full blown Unity. I have found the solution, in Tools depot, advance tools, you can prepend the digits.
I will give you credit for you answer any ways...thanks for you input, might need that for my future CUE installs.
Shir
Markus Schneider Fri, 07/10/2009 - 17:52
  • Cisco Employee,
You would have to make sure each Unity subscriber has an alternate extension added (with their 4-digit extension). Then you'd be able to dial the 4-digit extension and it would transfer out to the 11-digit extension (which would be the primary extension and transfer pattern). The Bulk Edit tool for Unity allows you to create these alternate extensions automatically. See:
http://www.ciscounitytools.com/App_BulkEditUtility_40.htm
Markus Schneider Fri, 07/10/2009 - 17:53
  • Cisco Employee,
