ACS SE 1113 ver 4.2 booting problem
abhishek.shukla
I have installed one ACS SE 1113 with ver 4.2. it was in working condition. Suddenly I am getting the message "disk read error Ctl+alt+del to restart" via console and it stops working. After pressing Ctl+alt+del, I am getting the same message.
Jagdeep Gambhir
Level 10
Level 10
Abhi,
Please try to reimage the appliance and that should fix it. Make sure you are using correct recovery CD or DvD.
~JG
Do rate helpful posts
Hi Gambhir,
I am trying to reimage with the CSACS SE 1113 recovery CD/DVD ver 4.2. But it is taking more than a hour and the cd/dvd drive is blinking only. No display on the console. Don't know when it will end. But as per docs it will take very little time to reimage.
Any clue/idea regarding how long it will take to complete ? Or any other options ?
Abhi,
Can you plug in monitor to appliance and see what message you are getting?
~JG
