IP Phone 7940
Jun 28th, 2009
The problem i have with the 7940 phone is that they keep showing the message Configuring IP randomly. To overcome this i usually unplug the phone from the network and then plug it back in and after that it works fine without any issue but this is not a proper solution so any one can help in this manner. I have CCM 4.2 and the DHCP for the phones are created on the Router.
gogasca Sun, 06/28/2009 - 23:21
  • Green, 3000 points or more
Make sure you are using latest phone load
Is phone resetting?
check EVent Viewer
Thats the topology
I would open a TAC case for more investigation
