Line group/Hunt pilot Question?
Jun 28th, 2009
Hello all,
I have a line group, all the members are in the group are using extension mobility. My question is, is it possible to forward all the calls coming to this group to a common voicemil box when all the members are not logged in.
And also i have tried personal preference setting in huntpilot configuration. Unfortunately that doesn't work. i have configured Callforward no coverage option in line configuration.
I appreciate for all the assistance.
Overall Rating: 3 (1 ratings)
gogasca Sun, 06/28/2009 - 23:11
you can add a cfna,cfb under hunt pilot.
and change called party info under hunt pilot to send the call to general vm vox.
Nahassamad_2 Sun, 06/28/2009 - 23:19
Thankyou for your fast response.
But can i use personal perference under huntpilot. ?
Jaime Valencia Mon, 06/29/2009 - 03:08
Yes, you can.
Exactly how are you trying to use the personal preference??
java
if this helps, please rate
Nahassamad_2 Mon, 06/29/2009 - 03:21
Actually the user(a huntgroup member) wants to get all the calls on their mobile phones when the user enable the call forward all on the phone. I believed that this would not work. So i suggested the user we can configure the mobile number in Callforward no coverage option under line configuration and enable personal preference in CFNA under huntpilot. I have tried this but this doesn't work.
Please advice..
Nahas
Jaime Valencia Mon, 06/29/2009 - 03:32
Personal preference works if you send the call with a call forward option to a hunt pilot, not if you call directly the hunt pilot.
You would need to call the user DIRECTLY, then use a call forward option to send the call to the hunt pilot, and only then if it reached the CFB or CFNA of HP it will follow the no coverage setting from the phone that FW the call in 1st place.
And you're right CFA is bypassed if a call arrives thru a hunt pilot, way tooooo many posts on that at NetPro if you want to review some.
java
Nahassamad_2 Mon, 06/29/2009 - 03:40
Thank you for your reply. Can you suggest a solution for implement this.?
Jaime Valencia Mon, 06/29/2009 - 03:44
Use SNR for that user if your version provides it.
java
