06-28-2009 11:03 PM - edited 03-06-2019 06:30 AM
I have a network with 4 different types of traffics and I would like to monitor them. I have 4 different Ports connected to different analyzers. Unfortunately I am only able to create 2 monitor sessions on my catalyst 3560G.
Is there any workaround or appliances that I could use to make this happen.
Thank You
Rushan
06-29-2009 02:54 AM
One solution would be to to SPAN all traffic but rely on sniffer to filter.
With 2 sessions and 4 streams, you would have to filter 2 streams per sniffer( at sniffer level).
Another solution is to trunk the remaining 2 streams to another switch and run 2 additional session there.
Sam
06-29-2009 05:48 AM
Thank you SAM.
06-29-2009 06:17 AM
Hi Rushan
Glad to help !
Please remember to use the rating system if the reply has helped in any way, so other readers can scan through posts and refer to posts if needed.
Sam
06-29-2009 06:34 AM
Hi Rushan
Glad to help !
Sam
