Cisco ATA186 & call manager config question?
Jun 28th, 2009
Hi There,
I hope I can get some assistance with a configuration issue that I'm facing when setting up a lab environment using a phone line, an ATA 186 and Call manager. I'm connecting a phone line (PSTN), to the ATA, which is connected to the same LAN as the call manager. It is configured to get an IP address by DHCP. This works fine as I can see the ATA registered in call manager with a valid IP address. The problem I'm facing is that as i'm not using a gateway and I'm not sure whether I can route calls via the ATA. As far as i understand only a gateway can be assigned to a route group, to be assigned to a route list and subsequently to a route pattern. So my question is whether I can somehow connect the phone line to the ATA, and configure it in call manager in such a way that I can receive and make calls via the number allocated to that phone line connected to the ATA without the need of a gateway?
I'll appreciate any input on this?
Kind Regards,
Esteban
Overall Rating: 4 (1 ratings)
gogasca Sun, 06/28/2009 - 23:19
  • Green, 3000 points or more
ATA has FXS ports not FXO ports
you cannot use ATA for routing calls to PSTN
You need Cisco IOS GW or other GW, not ATA
egua5261 Mon, 06/29/2009 - 16:57
Thanks. I have now a VIC card available, the VIC-2DID and a 2600 series router (2611). I've read that this card has dual working modes, FXS and DID. Do you know if the DID mode is equivalent to FXO? If yes can this VIC card be used in the 2611 router with a suitable IOS?
Esteban
Rob Huffman Tue, 06/30/2009 - 08:45
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Esteban,
This card will not work when connected directly to a "standard" Telco line, it requires a specifically configured DID Trunk from the Telco provider :(
Understanding Direct Inward Dial (DID) Voice Interface Cards
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a00800c67ec.shtml
Hope this helps!
Rob
egua5261 Tue, 06/30/2009 - 15:55
Hi Rob,
Since i need to connect a card directly to a standard Telco line, so i should be using an FXO voice interface card. I'm trying to get one. Do you know if the VIC2-2FXO will work on a cisco 2611? I can't seem to find a VIC-2FXO.
Best Regards,
Esteban
