Cisco CSS AAA with ACS server
Jun 29th, 2009
I have applied the below config to my CSS:-
virtual authentication primary tacacs
virtual authentication secondary local
tacacs-server key spire_tacacs
tacacs-server account config
tacacs-server x.x.x.x 49 primary
tacacs-server authorize config
Everything works with regards to authentication back to the ACS. Problem is when I create a new user and group with a specific command set, the CSS fails and in the log of the ACS under failed attempts it says that author failed with command denied (service=shell cmd=privilege).
The same command set works with a Cisco 4500/6500/7200 (you get the idea), but not the CSS. The only way it works is if you permit all commands which is not what I need.
Has anyone got any idea's on this?
Cheers
Steven
smalkeric Fri, 07/03/2009 - 11:42
  • Silver, 250 points or more
To add a user to a group, go to the User Setup section of the Cisco Secure ACS HTML interface:
•On the User Setup Select page, specify a username.
•On the User Setup Edit page, specify the following:
-Password Authentication - Select an applicable authentication type from the list.
-Password - Specify and confirm a password.
