OID power supply
p.maillot
Hi all,
I use an 1720 router and I need to know if there are an a possibility to check the power supply.
The electrical network is not stable and I want to know if there are possibility to count the number of cut?
Joe Clarke
No, the 1720 does not offer SNMP management of the power supply.
Thank you for this reply, I must replace my router, by a 871?
It's possible to have power managment information on 871?
No, the 871 does not offer power management via SNMP. You can see the list of platforms with CISCO-ENVMON-MIB support at http://tools.cisco.com/ITDIT/MIBS/AdvancedSearch?MibSel=4497&SUBMIT1=Submit . The various platforms will have different levels of support. It depends on hardware as to whether or not certain aspects of the ENVMON-MIB are supported.
