High CPU utilization when using multilink
Jun 29th, 2009
Hi ,
Facing high CPU utilization when using multilink with MPLS .
CPU utilization goes upto 85 % when using multilink.
Also need to know how many links I can configure in one multilink bundle. At present I am using 30 link in each bundle.
Hardware:
3 Gigabit Ethernet interfaces
63 Serial interfaces
1 Channelized STM-1 port
Cisco 7206VXR (NPE-G1) processor (revision B) with 229376K/32768K bytes of memory.
Istvan_Rabai Mon, 06/29/2009 - 08:34
Hi Bhalchandra,
It's natural that multilink causes such a high cpu utilization, especially when traffic is high.
One alternative solution to this could be using CEF load sharing to replace the multilink bundles.
This would very much reduce cpu utilization.
Cheers:
Istvan
Joseph W. Doherty Mon, 06/29/2009 - 11:10
Are you configured to support MLPPP fragmentation? If so, and if you don't need it, see if disabling it helps to reduce CPU.
