MLPPP
Jun 29th, 2009
Hi all,
I have a MLPPP with 2 T1's connecting the main branch and a remote branch. I called the telco to let them know I would be setting these T1's up as a multilink, incase they needed to do anything different. They told me nothing needed to be changed on their end and that the timing was coming from the router at our main branch. My questions are -
1 - Was the telco telling me the truth that nothing needed to be configured differently on their end?
2 - Is there a way to verify the timing is coming from our main router?
Thanks ahead of time for any help.
Collin Clark Mon, 06/29/2009 - 05:41
  • Purple, 4500 points or more
1- Yes, they have no configuration on their end for you to run MLPPP, it's done on your routers.
2- Check your config. You should have something like this on the head end;
controller T1 0/2/0
framing esf
clock source internal
linecode b8zs
channel-group 0 timeslots 1-24
and at the remote;
controller T1 0/2/0
framing esf
clock source line
linecode b8zs
Also here's a link on configuring MLPPP.
https://packetpros.com/cisco_kb/VWIC-MFT_MultiLinkPPP.html
Hope it helps.
derek.leonard Mon, 06/29/2009 - 05:51
We have no controller configurations on the routers. I have included a sample below.
interface Multilink1
ip address x.x.x.x x.x.x.x
load-interval 30
ppp multilink
ppp multilink group 1
service-policy output DATA
interface Serial0/2/0
no ip address
encapsulation ppp
no fair-queue
ppp multilink
Collin Clark Mon, 06/29/2009 - 05:53
OK, how about a line like the following?
network-clock-participate wic 0
derek.leonard Mon, 06/29/2009 - 05:55
No - the only network-clock-participate command in the config is no network-clock-participate slot 1.
derek.leonard Mon, 06/29/2009 - 06:53
No clocking commands on the other side.
I would say its half and half. Since the telco said that we are providing the clocking for this mlppp, I'd like to know where that is setup at. But, I also dont feel like we are getting the full bandwidth that we should be seeing with these 2 lines virutally bonded togother. I had called the telco to check the lines and they said everything tested clean - although that seems to be their programmed response.
Thanks for the link - I actually already have this in my favorites :)
Collin Clark Mon, 06/29/2009 - 06:56
Are you seeing high packet loss or latency? Are you getting any packet drops if you send something like 5000 pings across the line? A few months ago we had misconfigured timing and here's what we we're seeing (check the graph).
https://packetpros.com/cisco_kb/T1_Timing.html
