Network Assistans IOS Command Not Found
Jun 29th, 2009
I have Cisco Network Assistant, I am attempting to connect to Cisco 4402 WLAN Controller. However, on descovery I get "IOS Command Not Found". Can anyone help me connect ? Many thanks.
carenas123 Fri, 07/03/2009 - 05:03
  • Silver, 250 points or more
Network Assistant supports only autonomous access points. Access points that are managed by a wireless LAN controller are not supported.
If you run Cisco IOS 12.2(25)SEE or later, Cisco IOS 12.2(25)SEG or later, or Cisco IOS 12.1(22)EA7 or later, you must run Network Assistant 4.0 or later.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_network_assistant/version5_0/release/notes/OL12210a.html#wp775718
neilmac Fri, 07/03/2009 - 05:17
Thanks for the answer -
It's not the Access Points I want to connect to, it's the WLAN controller.
Neil
Lucien Avramov Fri, 07/03/2009 - 17:09
  • Red, 2250 points or more
The WLAN controllers are not supported in CNA per the release notes. Keep in mind CNA was designed for switch management.
For WLC management, you can use other products such as WCS.
