ACS 4.2 and User Session Timeout
Jun 29th, 2009
We are upgrading to ACS 4.2 that will be used to authenticate wireless users. It seems that if I limit simultaneous connections (for wireless users) to 1, then disconnect from wireless it takes around 3 minutes for ACS to release that connection so I can log in again. Is there any way I can decrease this time. I've been searching for such a setting but am unable to find anything.
Thanks.
Jagdeep Gambhir Mon, 06/29/2009 - 10:05
  • Red, 2250 points or more
This function works on the basis of accounting (stop start). Make sure you see "stop" for your username in radius accounting when you disconnect.
If you don't see that troubleshoot the accounting part.
~JG
Do rate helpful posts
PatrickKnee Tue, 06/30/2009 - 04:41
The problem here isn't that it won't "stop", but the time it takes to stop. Is there anyway to decrease the amount of time it takes?
darpotter Tue, 06/30/2009 - 05:56
  • Silver, 250 points or more
This is going to be a function of the wireless access point.
ACS will release the session internally as soon as the accounting stop arrives.
I recall with descendants of Aironet gear the RADIUS accounting used to be a bit flakey. Because wireless comes an AP will often wait to see if a client really has gone for good or just dropped out for a short time.
For that reason I do not think you can use ACS max sessions with wireless in a reliable way.
Jagdeep Gambhir Tue, 06/30/2009 - 10:45
See if you have this command available on aaa-client,
aaa accounting update newinfo
This command is used to enable periodic interim accounting records to be sent to the
accounting server .
The full syntax of the command is
aaa accounting update [newinfo] [periodic number [jitter {maximum max-value}]]
Syntax Description
newinfo
(Optional) An interim accounting record is sent to the accounting server whenever there is new accounting information to report relating to the user in question.
periodic
(Optional) An interim accounting record is sent to the accounting server periodically, as defined by the argument number.
number
(Optional) Integer specifying number of minutes.
jitter
(Optional) Allows you to set the maximum jitter value in periodic accounting.
maximum max-value
(Required) The number of seconds to set for maximum jitter in periodic accounting. The
value 0 turns off jitter. Jitter is set to 300 seconds (5 minutes) by default.
That should help
~JG
