CUCM 6.0 Installation on HP DL 380 G5
Answered Question
Jun 29th, 2009
Hi All,
I am trying to install CUCM 6.0 on HP DL 380G5 for lab purposes.
Specifications
Intel Xeon Processor @ 2.33 Ghz
2GB RAM DDR2
Physical Hard Drive 1, Controller Slot 1 73.4 Gbytes 10K RPM
Physical Hard Drive 2, Controller Slot 1 73.4 Gbytes 10K RPM
Physical Hard Drive 3, Controller Slot 1 73.4 Gbytes 10K RPM
While Starting installation i am stuck up with an error.
Error: not enough physical disks [ 3 disks present]
Error : could not create logical RAID drives
Smart Array P400 in slot 1
Controller Status : OK
Cache Status : OK
physicaldrive 1:1 (box 1:bay 1, 73.4 GB) : OK
physicaldrive 1:2 (box 1:bay 2, 73.4 GB) : OK
physicaldrive 1:3 (box 1:bay 3, 73.4 GB) : OK
Error : the Specified device does not have any logical drive
Any ideas ???
Thanks and regards.
Correct Answer by Jaime Valencia about 7 years 6 months ago
You need to either remove or add 1 HDD to make the # of disk an even number to install this.
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Mon, 06/29/2009 - 07:07
java
