Recovering from VTP updates
Answered Question
Jun 29th, 2009
Is there a way to recover from a switch being brought online inadvertently, which was configured as vtp server with a higher revision number, and incorrect vlan configurations? The switch updated the existing online switches.
Overall Rating: 5 (1 ratings)
glen.grant Mon, 06/29/2009 - 07:19
Do you have a backup config from your normal vtp servers ? You would also have to have a backup of your vlan.dat files from the servers to recover . Otherwise its probably a manual recovery on your main vtp servers once you pull off the offending switch that made the change or change it to transparent and back.
