Netflow on 2 interfaces
Jun 29th, 2009
I'm trying to configure Netflow on 2 router interfaces. I configure the first one, but when I add the commands to configure the second one the command for the first one dissapears. This is the configuration:
Interface Fastethernet0/0
ip address xxx.xxx.xxx.xxx 255.255.255.0
ip access-group 14 out
ip nat outside
ip virtual-reassembly
ip route-cache flow
load-interval 30
duplex auto
spped auto
Interface Vlan1
ip nat inside
ip route-cache flow
load-interval 30
ip flow-export destination 192.168.4.101 9996
ip flow-export source FastEthernet 0/0
ip flow-export version 5
ip flow-cache timeout active 1
ip flow-cache timeout inactive 15
snmp-server ifindex persist
With this configuration I can see Interface Fa0/0 but when I add:
ip flow-export source Vlan1
dessapears:
Is it possible to see both interfaces 'Active' on Netflow Analyzer at a time?
Thanks in advance
Edison Ortiz Mon, 06/29/2009 - 08:50
  • Hall of Fame,
    Founding Member
They are active as soon as you have 'ip route-cache flow' under the interface.
The command you are questioning, it's just changing the source interface that is going to be used to send this information to the collector.
If you don't enter any 'ip flow-export source' it will use the interface that is closest to the NetFlow collector. By entering the command, you are forcing the source to be X interface which is useful if you have FWs in the transit path and just want to allow that IP address in the rules.
HTH,
__
Edison.
usuario0001 Mon, 06/29/2009 - 08:54
But if so you can only send traffic from one interface to the collector at a time, is that correct?
Edison Ortiz Mon, 06/29/2009 - 08:58
  • Hall of Fame,
    Founding Member
No, that's not correct.
Per your configuration, both interfaces are collecting NetFlow traffic and storing that information to a local NetFlow database.
After a certain amount of traffic is collected locally, this information is sent to the NetFlow collector and when sending this information to the NetFlow collector an interface will be used. The interface is specified with the command in question. The command is optional and NetFlow will work without it unless you have FWs in the transit path that expect traffic from X sources.
In short, you can send 'NetFlow Information' from a specified interface but all interfaces with 'ip route-cache flow' will be reporting to this collector.
Richard Burts Mon, 06/29/2009 - 09:06
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Marian
While the answer from Edison is essentially correct I can see that it could be slightly confusing to those who do not already understand what IOS is doing. I would suggest that a slight change in his response would be less confusing. Edison says:"it's just changing the source interface that is going to be used to send this information to the collector." Actually what is specified is not what interface to use but is specifying what source address is to be used in the NetFlow packet. It is quite possible for Cisco to use the address of FastE0/0 and to send the packet out the interface FastE0/1.
So the command that you question is not specifying what interface to use and is specifying what source address to use.
Rick
