Does HUM 1.2 support formulas?
Answered Question
Jun 29th, 2009
I wanted to know if it's possible to define formulas in HUM 1.2 in order to divide the result of some SNMP queries, etc.
Many thanks.
Correct Answer by Joe Clarke about 7 years 11 months ago
Not really. There is a new feature called Trendwatch which allows you to define some formulaic analysis of threshold trends, but nothing that allows you to, say, calculate percent of used DS0s.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Mon, 06/29/2009 - 10:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
