Call Fwd. Report CUCM 6.1
Jun 29th, 2009
I would like to run a report to see what phones are forwarded to where.
Jaime Valencia Mon, 06/29/2009 - 10:25
Just by using a qry into the numplan table via CLI, no reporting on this via CCMadmin.
The fields are pretty self explanatory but you can look the data dictionary and just use the fields you're interested when running the qry.
if this helps, please rate
Jaime Valencia Mon, 06/29/2009 - 10:37
run sql
Then just write a qry in there
select * from numplan
If you want to fine tune this as i told you, either just look at the fields headers when you save this into a file or look at the data dictionary so you don't get all the info.
