SSL VPN Group Policies
Jun 29th, 2009
When user login SSL VPN (ASA 8.0), how to apply group policy base on their user name without to choose the gorup option at login page. The problem is when I check the option for user to choose the group at login page, it work fine. But without that group option, it always go to default group policy. Please advise.
Sai
Overall Rating: 5 (1 ratings)
Todd Pula Tue, 06/30/2009 - 11:49
This is working as designed. If you intend on having multiple connection profiles, you will need to rely on either aliasing with a selection menu or group URLs. If certificate authentication is used, you can use certificate maps to map a user to a particular connection profile based on fields in the cert. Without the above, the ASA has no way of knowing what connection profile to put the user in so it falls back to the default.
J2NoomSai_2 Tue, 06/30/2009 - 11:54
Hi Topula
Thanks for the answer. It help a lot. Do you know the link or document for configure group URLs?
