Switch Monitoring/Reporting
Jun 29th, 2009
I have a network with one 4500 series switch and around 9 3750 switches connected to the main location via fiber in a ring. I am looking for good preferably free utility to monitor bandwidth and events on these switches. Any suggestions?
bschear Mon, 06/29/2009 - 10:30
Those look good. I assume it is one or the other and not use both? Do you like one of the suggestions better?
cisco_lad2004 Mon, 06/29/2009 - 11:11
I have seen Hobbit used for fault management and cacti for performance. I believe you its also possible to set thresholds on cacti which when exceeded create alarms.
Sam
hobbe Tue, 06/30/2009 - 01:17
Yoy asked for a "preferable" free utility, I would check out Orion from solarwinds, its not free but for a small installation and it does not sound that you want to look at all the ports, it is not that expensive and you get a lot of good extra good stuff from it.
There are several free utilities but in general I think that you either get a software that you pay for in $ and it prepackaged to work "for you" or you get a free software and pay for it with your time to tinker around with it.
Either way you pay for it somehow.
