CSWinAgent restarting forever
Jun 29th, 2009
I re-installed the ACS Remote AGent (4.2) on a host where it was previously working. All permissions are still intact and the service has been reset to use the correct account. There is not CSWInagent log file but I do see this in the CSAgent log:
ACSRemoteAgent 06/29/2009 13:05:08 E 0194 1188 0x0 CSWinAgent has terminated unexpectedly
Does anyone know what those numbers mean? I see no other indication of why this is happenening.
thanks!
Jagdeep Gambhir Mon, 06/29/2009 - 11:32
  • Red, 2250 points or more
HI,
It seems like during installation of the Remote Agent, you missed to check windows authentication and that could be the reason for missing cswinagent.
A few of the possible reasons behind this problem are:
* A user without Admin privileges attempts to install Cisco
Secure ACS/RA on the server.
* This error message may occur because of an incompatibility
between RA and anti-virus or a host based Intrusion Detection System (IDS)
on the server.
* The uninstallation of a previous version did not go cleanly.
Note: This error message usually appears because of hidden files stored on
the server from a previous version.
Complete these steps in order to resolve this issue:
1. Make sure you are logged in with Admin privileges.
2. Any sort of anti-virus or host based IDSs must be turned off.
3. An older version on the Cisco Secure ACS server must be completely uninstalled.
I would suggest you reinstall it and make sure to check windows authen and remote logging.
~JG
Do rate helpful posts
