same-security access problem
Jun 29th, 2009
I'm trying to set-up two networks on two separate ASA ports and make them communicate with each other. I'm using the same security level (100) for them and I've checked the option for same-security level communication in ASDM. The problem is that I can't make this scenario work. The ASA interfaces are reachable from their networks but I can't ping between them(across the ASA). ACLs are set on permit any and I've set up also nat exemptions. The packet tracer shows no problem but ping or traceroute doesn't work. I also enabled icmp inspection. It's driving me crazy. Anyone know what I'm missing here? There is also a third interface used for internet access with NAT and it works.
robertson.michael Mon, 06/29/2009 - 12:19
  • Silver, 250 points or more
Hi Sergiu,
Can you post a sanitized version of your config? This will help us troubleshoot your issue.
Other than that, I would suggest setting up some packet captures to see exactly where the traffic is failing. This may give you a hint about where you should start your troubleshooting. Take a look at the 'capture' and 'show asp drop' commands:
'capture' Command Reference:
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/c1.html#wp2108895
'show asp drop' Command Reference:
Hope that helps.
-Mike
sergiu.campian Mon, 06/29/2009 - 22:07
Here's my current lab config (I replaced the real IP addresses). I'm trying to communicate between 192.168.1.0/24 and 172.16.0.0/24
ASA Version 8.0(4)
names
name 192.168.1.1 server
interface Ethernet0/0
nameif inside
security-level 100
ip address 192.168.1.254 255.255.255.0
interface Ethernet0/1
nameif wan2
security-level 0
ip address X.X.X.X 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
nameif vodafone
security-level 100
ip address 172.16.0.2 255.255.255.0
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list inside_nat_outbound extended permit ip 192.168.1.0 255.255.255.0 any
access-list inside_access_in extended permit ip any any
access-list wan2_access_in extended permit ip any any
access-list vodafone_access_in extended permit ip any any
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 17
2.16.0.0 255.255.255.0
access-list inside_access_out extended permit ip any any
access-list vodafone_access_out extended permit ip any any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu wan2 1500
mtu vodafone 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-613.bin
no asdm history enable
arp timeout 14400
nat-control
global (inside) 1 interface
global (wan2) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 192.168.1.0 255.255.255.0
static (inside,wan2) X.X.X.X server netmask 255.255.255.255
static (inside,inside) X.X.X.X server netmask 255.255.255.255
access-group inside_access_in in interface inside
access-group inside_access_out out interface inside
access-group wan2_access_in in interface wan2
access-group vodafone_access_in in interface vodafone
access-group vodafone_access_out out interface vodafone
router rip
network 172.16.0.0
passive-interface inside
passive-interface wan2
version 2
route wan2 0.0.0.0 0.0.0.0 Y.Y.Y.Y
route inside 172.16.0.0 255.255.0.0 172.16.0.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
vpn-addr-assign local reuse-delay 1
telnet timeout 5
ssh timeout 5
console timeout 0
management-access inside
dhcpd address 192.168.1.15-192.168.1.250 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map global-class
match any
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map type inspect dns MY_DNS_INSPECT_MAp
parameters
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
class global-class
inspect icmp
service-policy global_policy global
prompt hostname context
robertson.michael Tue, 06/30/2009 - 05:12
Hi Sergiu,
I copied your config into my test ASA and was able to ping across without any issues.
I would suggest checking the routing tables of the clients that you are pinging between to make sure they are correct (in a simple topology they would probably have a default route of the appropriate ASA interface). You can check this with the 'route print' command on Windows or the 'route' command on Linux.
I would also set up a few captures on the ASA to see where the ping is actually failing. You might setup something like this:
access-list ping-acl permit icmp 172.16.0.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list ping-acl permit icmp 192.168.1.0 255.255.255.0 172.16.0.0 255.255.255.0
capture capin access-list ping-acl interface inside
capture capvod access-list ping-acl interface vodafone
capture drop type asp-drop all
Once you have these captures configured, try pinging again. Then:
'show capture capin' will show you which packets hit the inside interface
'show capture capvod' will show you which packets hit the vodafone interface
'show capture drop' and 'show asp drop' will show you which packets were dropped by the ASA and the reason for the drop
Here are a few command references:
'capture':
'show asp drop':
Let us know what you find.
-Mike
