Wireless Clients
Jun 29th, 2009
I am trying to setup the clients on our network with the Intel Wireless Utility package and in the administrative tool gives an option to setup Roaming Aggressiveness and i am not quite sure which option to use:
Default: Balanced between not roaming and performance
· Lowest: Your WiFi client will not roam unless significant link quality degradation occurs
· Highest: Your WiFi client continuously tracks the link quality and, if any degradation occurs, it tries to find and roam to a better access point
Thank you
Vic
Overall Rating: 5 (1 ratings)
George Stefanick Mon, 06/29/2009 - 17:31
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
For your own benefit I would test on your own a client in the low mid and high level of roaming agressivness, so you can see for yourself.
We have our 2,000+ clients on the Intel with HIGH aggressive roaming and they work well. I did some testing with clients on mid and low and they didn't to bad either.
If you have clients jumping to quick then you may want to tune it down.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
