How to generate the seed file
Answered Question
Jun 29th, 2009
I've been reading Cisco official guide on CS-MARS and found only a sample of such a file. How could it be done in the first place? Can any one show me a sample of how it looks in the spreadsheet ? I would be more interested in adding agents from CSA and Symantec AV.
Eugene
Correct Answer by eegilbert about 7 years 12 months ago
I don't, but you can use this document to design one on your own. I would start small, say 5 hosts just to make sure you are getting the schema correct.
Erric
Overall Rating: 3 (1 ratings)
zheka_pefti Mon, 06/29/2009 - 14:34
Thanks, Eric.
This is exactly what I meant. Do you have a sample of a spreadsheet file.
Correct Answer
eegilbert Mon, 06/29/2009 - 14:47
Erric
patwill66_2 Tue, 06/30/2009 - 04:21
This is the format I use when importing servers. I just create a .csv file in notepad to bulk upload my servers. Even if i am just doing a few its easier.
One thing to mention, dont have a carriage return at the end of your file otherwise it will error out.
You can find all the device types listed in the MARS configuration guide.
server1,SNMPCommunityName,,,Windows2003,SNMP,,,,,,,,,,,,,,,10.1.1.101
server2,SNMPCommunityName,,,Windows2003,SNMP,,,,,,,,,,,,,,,10.1.1.102
server3,SNMPCommunityName,,,Windows2003,SNMP,,,,,,,,,,,,,,,10.1.1.103
server4,SNMPCommunityName,,,Windows2003,SNMP,,,,,,,,,,,,,,,10.1.1.104
