ip alias in the redundant setup
Jun 29th, 2009
We're trying to setup a redundancy for the 2 ACE modules in the separate 65xx and were wondering if we would need to setup an ip alias address. what is it for anyway?
Thanks..
dario.didio Mon, 06/29/2009 - 23:52
  • Silver, 250 points or more
an alias IP is like an HSRP or VRRP address between two routers. It provides a shared IP address between the two redundant ACEs.
It should be used in routed mode as default gateway for the servers or as next-hop for the upstream router to reach the subnets behind the ACE.
more info can be found here:
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A2/configuration/rtg_brdg/guide/vlansif.html#wp1034811
HTH,
Dario
