Pix PDM doesn't open
Jun 29th, 2009
I need help...We had a local firm setup our Pix 500 series firewalls and they disabled the http interfaces. I am not that great at the command line arguements and work much better via the browser based window. I now need to make a couple of modifications and I thought I had the issue fixed but I cannot get it to open the PDM. I get prompted for a user name and password twice but never get past the "Loading Pix Device Manager. Please Wait..." screen.
mgostovich Tue, 06/30/2009 - 11:14
I did this with a local user and password with level 15 privileges and get the same problem
ph0enix Tue, 06/30/2009 - 12:11
What version of Java runtime do you have installed? I've had similar problems with versions newer than 1.4.2.18.
John Blakley Tue, 06/30/2009 - 12:58
  • Purple, 4500 points or more
Yes, it's usually java related. I would try a different java vm.
HTH,
John
mgostovich Thu, 07/02/2009 - 14:28
Ya I am running java 6 update 11. I will try uninstalling my version and putting an older one in
