Tom of Day - Phone Services eg extention mobility
Answered Question
Jun 29th, 2009
Hi guys, is there any way I can control users to access the phone service like extention mobility based on time of day ? for example, after hours, new user can't login and existing user was forced to logout ?
Peng
Correct Answer by Jaime Valencia about 8 years 3 weeks ago
No, that is not implemented in any version.
There is also no timer for EM such as "after 20:00 logout everyone"
Then only timer for EM is to logout user after X hours.
I'd recommend you to get in touch with your AM to submit a PER on those features if you want them.
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Mon, 06/29/2009 - 18:42
  • Cisco Employee,
  • Hall of Fame,
    2011
java
acharyr123 Thu, 07/02/2009 - 09:06
Hi Java,
I need an information from you. I want after office hrs certain users will not be able to make any offnet calls...Is this possible?? If so can you plz suggest me the steps!!
Jaime Valencia Thu, 07/02/2009 - 09:18
  • Cisco Employee,
  • Hall of Fame,
    2011
This was on CUCM so i'm going with the idea you're also talking about CUCM.
Yes, use the TOD feature and segment the route patterns using CSS and partitions.
You can configure the after-hours route pattern with the same pattern but selecting block this calls.
BTW: please open new threads on NetPro as this is not related to the original post. You should only add if you're following the original subject.
java
