input queue drops are increasing
Jun 29th, 2009
I am facing input queue drops on the Gi interface. Please give the troubleshooting tech note. Here is the output of show interface.
GigabitEthernet1/1 is up, line protocol is up
Hardware is C6k 1000Mb 802.3, address is 0005.7485.4014 (bia 0005.7485.4014)
Description: << Uplink to Primary Core Switch - 10.15.3.65[Gig 5/1] >>
Internet address is 10.15.29.2/30
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 6/255, rxload 8/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s
Last clearing of "show interface" counters 00:02:51
Input queue: 0/1000/304/304 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue :0/40 (size/max)
30 second input rate 34437000 bits/sec, 5598 packets/sec
30 second output rate 26262000 bits/sec, 5891 packets/sec
L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 0 pkt, 0 bytes
992671 packets input, 898355211 bytes, 0 no buffer
Received 958 broadcasts, 0 runts, 0 giants, 0 throttles
953918 packets output, 426466273 bytes, 0 underruns
0 lost carrier, 0 no carrier
Appreciate immediate reply.
Istvan_Rabai Mon, 06/29/2009 - 22:31
  • Gold, 750 points or more
Hi Amit,
You have 992671 packets input, and 304 packets dropped, which is about 0.03%, and this can even be acceptable.
These packet drops could happen because of temporary overloads of the interface input queue.
Cheers:
Istvan
amitmarathe Mon, 06/29/2009 - 22:35
Can i manipulate configuration to nullify the drops. Please revert.
cisco_lad2004 Mon, 06/29/2009 - 23:02
1-issue a "clear counter GE1/1" command , and then u can monitor efficiently ( I see u have done that ).
2- what platform is this ?
3- "sh int ge1/1 queuing" this will give u an idea about Q status.
Sam
amitmarathe Mon, 06/29/2009 - 23:07
even after clearing the counter the drops are increasing. If you see the output
queue size is 0.
Do i need to configure QOS for this.
cisco_lad2004 Mon, 06/29/2009 - 23:09
u probably need to make Q deeper, let see what can be done once we know which platform it is.
what is the state of conncted port at other end ?
amitmarathe Mon, 06/29/2009 - 23:38
On the other end switch output queue drop not found. both end MTU is default. platform is 6509. Its a L3 port. Even after increasing load-interval to 1000 drops are increasing in same rate. Is any issue with gibic module.
cisco_lad2004 Tue, 06/30/2009 - 00:05
u had already 1000 to start with , so u need to go over a bit. Could be some bursty traffic causing this.
Sam
cisco_lad2004 Mon, 06/29/2009 - 23:16
Under GE1/1
"hold-queue X in"
X=1000 in ur case, keep increasing slowly and monitor if it solves the issue.
Sam
Joseph W. Doherty Tue, 06/30/2009 - 04:16
Cisco's "Output Interpreter" has this to say:
"INFO: There have been 304 flushes on this interface. Flushes are similar to input
drops, but are proactively forced by the router before the input queue is full.
Selective Packet Discard (SPD) is the congestion avoidance mechanism used, where
non-control packets are dropped in preference to control packets (i.e. routing
updates). Monitor the number of flushes. If they continue to increment, consider
increasing the size of the input queue and/or improving the switching mechanism
used by this interface (e.g. change process switching to fast switching). 'Flushes'
troubleshooting can be treated similar to input drops.
REFERENCE: For more information, see Troubleshooting Input Drops."
The actual link reference is: http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a0080094791.shtml
The above doesn't directly address trouble shooting this issue on a 6500, so I found two more references, although neighter is specific:
http://www.cisco.com/en/US/products/hw/routers/ps167/products_tech_note09186a0080094320.shtml
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a00804916e0.shtml
Considering the low drop %, I also agree with poster that it might be left alone.
Perhaps part of the problem might be related to the type of 6500 card you're using?
If a "cure" can't be found on the 6500, you might be able to fix by slowing the traffic on the other side's egress. In this interface snapshot, slowing to 100 Mbps would decrease possible bursts yet might preclude the drops.
