HSRP state
Jun 29th, 2009
we planned to run HSRP on our BGP router which is state is not changing fron learning to any state both of the routers are in learning state only
the network digram in attached as an attachment
when i debug i see the message as
on primary is seen as
*Oct 8 06:45:03.119: HSRP: Gi0/3 interface adv out, Passive, active 0 passive 2
*Oct 8 06:45:04.651: HSRP: Gi0/3 interface adv in, Passive, active 0, passive 1, from xxx.xx.44.38
*Oct 8 06:45:29.275: HSRP: Gi0/3 interface adv out, Passive, active 0 passive 2
*Oct 8 06:45:32.263: HSRP: Gi0/3 interface adv in, Passive, active 0, passive 1, from xxx.xx.44.38
*Oct 8 06:45:58.095: HSRP: Gi0/3 interface adv out, Passive, active 0 passive 2
*Oct 8 06:46:02.067: HSRP: Gi0/3 interface adv in, Passive, active 0, passive 1, from xxx.xx.44.38
*Oct 8 06:46:27.351: HSRP: Gi0/3 interface adv out, Passive, active 0 passive 2
*Oct 8 06:46:31.023: HSRP: Gi0/3 interface adv in, Passive, active 0, passive 1, from xxx.xx.44.38
on secondary
*Oct 8 06:45:03.119: HSRP: Gi0/3 Redirect adv out, Passive, active 0 passive 2
*Oct 8 06:45:04.651: HSRP: Gi0/3 REDIRECT adv in, Passive, active 0, passive 1, from XXx.XX.34.17
*Oct 8 06:45:29.275: HSRP: Gi0/3 Redirect adv out, Passive, active 0 passive 2
*Oct 8 06:45:32.263: HSRP: Gi0/3 REDIRECT adv in, Passive, active 0, passive 1, from XXX.XX.34.17
*Oct 8 06:45:58.095: HSRP: Gi0/3 Redirect adv out, Passive, active 0 passive 2
*Oct 8 06:46:02.067: HSRP: Gi0/3 REDIRECT adv in, Passive, active 0, passive 1, from XXX.XX.34.17
*Oct 8 06:46:27.351: HSRP: Gi0/3 Redirect adv out, Passive, active 0 passive 2
*Oct 8 06:46:31.023: HSRP: Gi0/3 REDIRECT adv in, Passive, active 0, passive 1, from XXX.XX.34.17
were will be the problem and moreover we are using 3 com l2 switch for wan connectivity and giving uplink for HSRP
is it correct way
pls advice
milan.kulik Mon, 06/29/2009 - 23:43
  • Red, 2250 points or more
I met similar problem in the past.
HSRP Hello frames are multicasts.
And some 3Com switches don't forward multicasts by default.
So I had to enable multicast forwarding on 3Com switches to make HSRP working.
Possibly you are in the same trouble?
BR,
Milan
vinoth.kumar Mon, 06/29/2009 - 23:49
Thanks for your reply
can i know how the debug messages are showing IN and OUT some message reaching between the two HSRP enabled router
can i know if u have any idea on this messges
i will check this update on my 3com switch
thanks
milan.kulik Tue, 06/30/2009 - 00:54
to be frank, I don't understand that debug messages. They seem to show you are receiving HSRP Hellos from both sides.
So I might have been wrong and the problem is not the 3Com switch.
Another idea:
You are using
standby ip ... secondary
on both routers, aren't you?
I've got a feeling this might be incorrect, as I've found an explanation saying the secondary keyword does not mean "use secondary IP address" (as I'd expect) but "become a secondary HSRP router" (should be used if no HSRP priority was configured).
The example in
http://www.cisco.com/en/US/products/ps6600/prod_bulletin09186a00800a3d9e.html
is pretty confusing, as using "secondary" only on one router.
I made a quick test on one of my routers and it seems I'm correct.
So try to remove the "secondary" option from your "stanby ip ..." commands and your HSRP might start working.
BR,
Milan
vinoth.kumar Tue, 06/30/2009 - 21:19
Sorry its mistakely written
xx.58.141.252 or 253)
thanks any advice on this issue
crow930us Wed, 07/01/2009 - 02:49
  • Bronze, 100 points or more
Compare the 'show HSRP detail' command results for each device. That might give you some more info.
hth
milan.kulik Wed, 07/01/2009 - 04:14
can you paste here the whole HSRP config section from both your routers?
BR,
Milan
vinoth.kumar Wed, 07/01/2009 - 04:24
the config
RTR-PRI:
interface GigabitEthernet0/3
description Telecity-PRI
ip address XX.58.141.252 255.255.255.0 secondary
ip address XX.20.34.17 255.255.255.0
duplex auto
speed auto
media-type rj45
no negotiation auto
standby 30 ip XX.58.141.254 secondary
standby 30 priority 110
standby 30 preempt
RTR-SEC:
description TELECITY BACKUP 27.10.2006
ip address XX.58.141.253 255.255.255.0 secondary
ip address XX.20.44.38 255.255.255.252
media-type rj45
speed auto
duplex auto
negotiation auto
no cdp enable
milan.kulik Wed, 07/01/2009 - 04:58
have you tried to remove the "sedcondary" option from
commands?
BR,
Milan
Vinoth, can you ping the secondary addresses from one another? This will have to be done using an extended ping sourcing your secondary IP address. I noticed that the primary IP addresses of both routers are in two different subnets which suggests that interface gi0/3 on both routers are not in the same vlan.
