cisco_lad2004 Tue, 06/30/2009 - 02:24
This typically happens when route is not known on the switch resulting in packets punted to CPU.
Can you paste
1-HSRP Config
2-show standby
3-show ip route.
Are you using SDM ?
Sam
John Patrick Lopez Tue, 06/30/2009 - 02:48
interface Vlan50
description access switch management
ip address 8.99.72.50 255.255.255.224
ip pim sparse-dense-mode
standby 50 ip 8.99.72.33
standby 50 timers msec 500 msec 1500
standby 50 preempt delay minimum 120
end
sjo2-3750G#sh standby vlan 50
Vlan50 - Group 50
State is Active
2 state changes, last state change 1d10h
Virtual IP address is 8.99.72.33
Active virtual MAC address is 0000.0c07.ac32
Local virtual MAC address is 0000.0c07.ac32 (v1 default)
Hello time 500 msec, hold time 1500 msec
Next hello sent in 0.374 secs
Preemption enabled, delay min 120 secs
Active router is local
Standby router is 8.99.72.51, priority 72 (expires in 1.416 sec)
Priority 100 (default 100)
IP redundancy name is "hsrp-Vl50-50" (default)
sjo2-3750G#
sjo2-3750G#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 14.59.0.85 to network 0.0.0.0
14.0.0.0/30 is subnetted, 1 subnets
C 14.59.0.84 is directly connected, Vlan20
8.0.0.0/8 is variably subnetted, 10 subnets, 6 masks
C 8.99.73.0/24 is directly connected, Vlan51
C 8.99.72.1/32 is directly connected, Loopback0
S 8.99.72.0/22 is directly connected, Null0
C 8.99.74.0/24 is directly connected, Vlan55
C 8.99.72.32/27 is directly connected, Vlan50
C 8.99.72.64/26 is directly connected, Vlan52
C 8.104.134.148/30 is directly connected, Vlan10
C 8.99.72.128/27 is directly connected, Vlan53
C 8.99.72.160/27 is directly connected, Vlan54
C 8.99.72.192/26 is directly connected, Vlan1
B* 0.0.0.0/0 [170/0] via 14.59.0.85, 2w6d
sjo2-3750G#
We are just using the default SDM template.
John Patrick Lopez Tue, 06/30/2009 - 03:00
sjo2-3750G#sh sdm prefer
The current template is "desktop default" template.
The selected template optimizes the resources in
the switch to support this level of features for
8 routed interfaces and 1024 VLANs.
number of unicast mac addresses: 6K
number of IPv4 IGMP groups + multicast routes: 1K
number of IPv4 unicast routes: 8K
number of directly-connected IPv4 hosts: 6K
number of indirect IPv4 routes: 2K
number of IPv4 policy based routing aces: 0
number of IPv4/MAC qos aces: 0.5K
number of IPv4/MAC security aces: 1K
sjo2-3750G#
We are using desktop default.
