Blocking incoming numbers on voice gateway CUCM 5
Jun 30th, 2009
Hi there all
Can someone please inform of the best method to block unwanted spam calls hitting one of our DDI numbers. I have done this some time back by using the rule reject /xxxx/ and the applying a profile to the PSTN dial peer. However we are using MGCP so peers not configured. Am I missing something really silly? Is it possible within CUCM
simonmossman Tue, 06/30/2009 - 04:44
I have researched this and found that the easy method would be to create translation pattern. However, as I cannot filter on the ANI only the DNIS then this would mean all calls to the DDI would would have to be routed to a CSS containing nothing.
Any other ideas most welcome
simonmossman Fri, 03/19/2010 - 05:45
Sorry for the huge delay Rob......I always value your input.....thanks
rob.huffman Fri, 03/19/2010 - 06:03
Hey Simon,
No worries! As they say "better late than never" my friend
