VPN gets disconnected randomly
Jun 30th, 2009
VPN gets disconnected randomly once in a while and i get the following error on the debug:
3|Jun 30 2009|11:46:27|713048|||Group = Grupo_VPNClient_Syges, IP =, Error processing payload: Payload ID: 14
3|Jun 30 2009|11:46:27|713902|||Group = Grupo_VPNClient_Syges, IP =, Removing peer from peer table failed, no match!
4|Jun 30 2009|11:46:27|713903|||Group = Grupo_VPNClient_Syges, IP =, Error: Unable to remove PeerTblEntry
4|Jun 30 2009|11:46:27|113019|||Group = , Username = , IP =, Session disconnected. Session Type: , Duration: 0h:00m:02s, Bytes xmt: 0, Bytes rcv: 0, Reason: Unknown
5|Jun 30 2009|11:46:27|713904|||IP =, Received encrypted packet with no matching SA, dropping
On the recommended actions says that it could be a misconfigured peer.
Could someone help me out to fix the problem?
mariapenilla Mon, 07/06/2009 - 00:24
The device we are using is an ASA 5505.
I have disabled “isakmp keepalive” in tunnel-group ipsec-attributes, using the command “isakmp keepalive disable”.
I have made the vpn-idle-timeout to none on the group-policy attributes.
DPD setting is set to maximum which is 480 seconds on the VPN Client.
- sysopt connection permit-vpn
- crypto isakmp nat-traversal
Have you got any more possible solutions?
yogesh2009 Thu, 10/08/2009 - 03:28
Didnt you see this message ? Received encrypted packet with no matching SA, dropping . That is the problem.
