chrisluven Tue, 06/30/2009 - 03:10
Close the Router log viewer and reopen it.
Maybe the Log viewer is connected to the side that is in idle state at the moment.
That can happen when the side changes while the log viewer is still open.
Chris
fabien.damien Tue, 06/30/2009 - 04:15
Hi Chris,
Thanks for your reply. i tried that, i even restarted the whole server with no resolution.
david.macias Tue, 06/30/2009 - 06:09
  • Blue, 1500 points or more
On the top left corner does it say disconnected? If you click on Log > Options what are is your refresh interval and max log entries?
david
