What is wrong with this HSRP config? Can't ping between these two routers
Jun 30th, 2009
Without debug ip packet or sniffer, I can't seem to pin point the reason on why these two 2811 routers connected via x-over cable from fa0/1/3 of Router1 to fa0/1/3 of Router2 cannot get layer 3 up although layer 2 is up and CDP neigbors are seen.
fa0/1/3 and vlan 70 are both up on both routers, yet no IP connectivity.
There is something simple I am missing.
Router1:
IOS used: c2800nm-adventerprisek9-mz.124-9.T1.bin
interface FastEthernet0/1/3
switchport access vlan 70
duplex full
speed 100
interface Vlan70
ip address 1.1.10.2 255.255.255.0
standby 20 ip 1.1.10.1
standby 20 priority 120
standby 20 preempt
Router1(vlan)show
VLAN ISL Id: 70
Media Type: Ethernet
VLAN 802.10 Id: 100070
State: Operational
MTU: 1500
Router1#show standby
Vlan70 - Group 20
State is Active
5 state changes, last state change 05:48:41
Virtual IP address is 1.1.10.1
Active virtual MAC address is 0000.0c07.ac14
Local virtual MAC address is 0000.0c07.ac14 (v1 default)
Hello time 3 sec, hold time 10 sec
Next hello sent in 1.616 secs
Preemption enabled
Active router is local
Standby router is unknown
Priority 120 (configured 120)
show interface shows:
FastEthernet0/1/3 is up, line protocol is up
Vlan70 is up, line protocol is up
show cdp neighbor shows Router2 as neighbor on fa0/1/3
Router2:
duplex full
speed 100
interface Vlan70
ip address 1.1.10.3 255.255.255.0
standby 20 preempt
Router2(vlan)show
VLAN ISL Id: 70
State: Operational
MTU: 1500
Router2#show standby
Vlan70 - Group 20
State is Active
5 state changes, last state change 05:59:58
Next hello sent in 0.708 secs
Preemption enabled
Priority 100 (default 100)
FastEthernet0/1/2 is up, line protocol is up
show cdp neighbor shows Router1 as neighbor on fa0/1/3
John Blakley Tue, 06/30/2009 - 05:37
  • Purple, 4500 points or more
Under Router2, you have:
duplex full
speed 100
Under the same router's "sh int", it shows:
Can you post fa0/1/3's sh int?
Can you ping the other router sourcing from the physical ip on either router?
HTH,
John
glen.grant Tue, 06/30/2009 - 05:50
Can you ping between the addresses ? Are these interfaces on a hwic ? Don't see anything obvious either. Trying adding the command "switchport" to both interfaces .
mschooley Tue, 06/30/2009 - 09:06
one other question, not really related, but you want preempt on both of them?
astanislaus Tue, 06/30/2009 - 21:47
On r1 - we confirmed Layer2 is up for fa0/1/2 and vlan70
RISSGP0114(config)#int f0/1/2
RISSGP0114(config-if)#sw mode acces
RISSGP0114(config-if)#end
Jul 1 01:16:17.140 GMT+8: %SYS-5-CONFIG_I: Configured from console by ga2reye on vty0 (10.200.20.13)
RISSGP0114#
RISSGP0114#
RISSGP0114#sh run int f0/1/2
Building configuration...
Current configuration : 62 bytes
interface FastEthernet0/1/2
end
RISSGP0114#sh run int vlan 70
Current configuration : 144 bytes
interface Vlan70
description Test
ip address 1.1.1.1 255.255.255.0
standby 20 ip 1.1.1.3
standby 20 preempt
end
RISSGP0114#
RISSGP0114#
RISSGP0114#debug ip packet 100 detail
IP packet debugging is on (detailed) for access list 100
RISSGP0114#
RISSGP0114#debug arp
ARP packet debugging is on
RISSGP0114#
RISSGP0114#
RISSGP0114#
RISSGP0114#
RISSGP0114#
RISSGP0114#ping 1.1.1.2
Sending 5, 100-byte ICMP Echos to 1.1.1.2, timeout is 2 seconds:
Jul 1 01:10:05.722 GMT+8: IP: tableid=0, s=1.1.1.1 (local), d=1.1.1.2 (Vlan70), routed via RIB
Jul 1 01:10:05.722 GMT+8: IP: s=1.1.1.1 (local), d=1.1.1.2 (Vlan70), len 100, sending
Jul 1 01:10:05.722 GMT+8: ICMP type=8, code=0
Jul 1 01:10:05.722 GMT+8: IP ARP: creating incomplete entry for IP address: 1.1.1.2 interface Vlan70
Jul 1 01:10:05.722 GMT+8: IP ARP: sent req src 1.1.1.1 0017.59de.ac90,
dst 1.1.1.2 0000.0000.0000 Vlan70
Jul 1 01:10:05.722 GMT+8: IP: s=1.1.1.1 (local), d=1.1.1.2 (Vlan70), len 100, encapsulation failed
Jul 1 01:10:05.722 GMT+8: ICMP type=8, code=0.
Jul 1 01:10:07.722 GMT+8: IP: tableid=0, s=1.1.1.1 (local), d=1.1.1.2 (Vlan70), routed via RIB
Jul 1 01:10:07.722 GMT+8: IP: s=1.1.1.1 (local), d=1.1.1.2 (Vlan70), len 100, sending
Jul 1 01:10:07.722 GMT+8: ICMP type=8, code=0
Jul 1 01:10:07.722 GMT+8: IP ARP: sent req src 1.1.1.1 0017.59de.ac90,
Jul 1 01:10:07.722 GMT+8: IP: s=1.1.1.1 (local), d=1.1.1.2 (Vlan70), len 100, encapsulation failed
Jul 1 01:10:09.722 GMT+8: IP: s=1.1.1.1 (local), d=1.1.1.2 (Vlan70), len 100, encapsulation failed
Jul 1 01:10:09.722 GMT+8: ICMP type=8, code=0.
Jul 1 01:10:11.722 GMT+8: IP: tableid=0, s=1.1.1.1 (local), d=1.1.1.2 (Vlan70), routed via RIB
Jul 1 01:10:11.722 GMT+8: IP: s=1.1.1.1 (local), d=1.1.1.2 (Vlan70), len 100, sending
Jul 1 01:10:11.722 GMT+8: ICMP type=8, code=0
Jul 1 01:10:11.722 GMT+8: IP ARP: sent req src 1.1.1.1 0017.59de.ac90,
Jul 1 01:10:11.722 GMT+8: IP: s=1.1.1.1 (local), d=1.1.1.2 (Vlan70), len 100, encapsulation failed
Jul 1 01:10:11.722 GMT+8: ICMP type=8, code=0.
Jul 1 01:10:13.722 GMT+8: IP: tableid=0, s=1.1.1.1 (local), d=1.1.1.2 (Vlan70), routed via RIB
Jul 1 01:10:13.722 GMT+8: IP: s=1.1.1.1 (local), d=1.1.1.2 (Vlan70), len 100, sending
Jul 1 01:10:13.722 GMT+8: ICMP type=8, code=0
Jul 1 01:10:13.722 GMT+8: IP ARP: sent req src 1.1.1.1 0017.59de.ac90,
Jul 1 01:10:13.722 GMT+8: IP: s=1.1.1.1 (local), d=1.1.1.2 (Vlan70), len 100, encapsulation failed
Jul 1 01:10:13.722 GMT+8: ICMP type=8, code=0.
Success rate is 0 percent (0/5)
RISSGP0114#
Jul 1 01:10:18.654 GMT+8: IP ARP: rcvd req src 172.10.220.129 0009.0f09.1600, dst 172.10.220.4 FastEthernet0/0
RISSGP0114#sh access-list 100
Extended IP access list 100
10 permit ip any host 1.1.1.2 (15 matches)
RISSGP0114#
astanislaus Tue, 06/30/2009 - 21:49
And same on other router
ISSGP0115(config)#int f0/1/2
RISSGP0115(config-if)#sw mode access
RISSGP0115(config-if)#end
Jul 1 01:16:02.127 GMT+8: %SYS-5-CONFIG_I: Configured from console by ga2reye on vty0 (10.200.20.13)
RISSGP0115#debug ip packet 100 detail
RISSGP0115#debug arp
RISSGP0115#
RISSGP0115#sh run int
Jul 1 01:16:17.140 GMT+8: %SYS-5-CONFIG_I: Configured from console by ga2reye on vty0 (10.200.20.13) f0/1/2
end
RISSGP0115#sh run int vlan 70
Current configuration : 119 bytes
interface Vlan70
description Test
ip address 1.1.1.2 255.255.255.0
standby 20 preempt
end
RISSGP0115#
RISSGP0115#ping 1.1.1.1
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Jul 1 01:16:29.076 GMT+8: IP: tableid=0, s=1.1.1.2 (local), d=1.1.1.1 (Vlan70), routed via RIB
Jul 1 01:16:29.076 GMT+8: IP: s=1.1.1.2 (local), d=1.1.1.1 (Vlan70), len 100, sending
Jul 1 01:16:29.076 GMT+8: ICMP type=8, code=0
Jul 1 01:16:29.076 GMT+8: IP ARP: creating incomplete entry for IP address: 1.1.1.1 interface Vlan70
Jul 1 01:16:29.076 GMT+8: IP ARP: sent req src 1.1.1.2 001f.6c95.66d0,
dst 1.1.1.1 0000.0000.0000 Vlan70
Jul 1 01:16:29.076 GMT+8: IP: s=1.1.1.2 (local), d=1.1.1.1 (Vlan70), len 100, encapsulation failed
Jul 1 01:16:29.452 GMT+8: IP ARP: rcvd req src 172.10.220.129 0009.0f09.1600, dst 172.10.220.5 FastEthernet0/0
Jul 1 01:16:29.452 GMT+8: IP ARP: sent rep src 172.10.220.5 001f.6c95.66d0,
dst 172.10.220.129 0009.0f09.1600 FastEthernet0/0.
Jul 1 01:16:31.072 GMT+8: IP: tableid=0, s=1.1.1.2 (local), d=1.1.1.1 (Vlan70), routed via RIB
Jul 1 01:16:31.072 GMT+8: IP: s=1.1.1.2 (local), d=1.1.1.1 (Vlan70), len 100, sending
Jul 1 01:16:31.072 GMT+8: ICMP type=8, code=0
Jul 1 01:16:31.072 GMT+8: IP ARP throttled out the ARP Request for 1.1.1.1
Jul 1 01:16:31.072 GMT+8: IP: s=1.1.1.2 (local), d=1.1.1.1 (Vlan70), len 100, encapsulation failed
Jul 1 01:16:31.072 GMT+8: ICMP type=8, code=0.
Jul 1 01:16:33.072 GMT+8: IP: tableid=0, s=1.1.1.2 (local), d=1.1.1.1 (Vlan70), routed via RIB
Jul 1 01:16:33.072 GMT+8: IP: s=1.1.1.2 (local), d=1.1.1.1 (Vlan70), len 100, sending
Jul 1 01:16:33.072 GMT+8: ICMP type=8, code=0
Jul 1 01:16:33.072 GMT+8: IP ARP: sent req src 1.1.1.2 001f.6c95.66d0,
Jul 1 01:16:33.072 GMT+8: IP: s=1.1.1.2 (local), d=1.1.1.1 (Vlan70), len 100, encapsulation failed
Jul 1 01:16:33.072 GMT+8: ICMP type=8, code=0.
Jul 1 01:16:35.072 GMT+8: IP: tableid=0, s=1.1.1.2 (local), d=1.1.1.1 (Vlan70), routed via RIB
Jul 1 01:16:35.072 GMT+8: IP: s=1.1.1.2 (local), d=1.1.1.1 (Vlan70), len 100, sending
Jul 1 01:16:35.072 GMT+8: ICMP type=8, code=0
Jul 1 01:16:35.072 GMT+8: IP ARP: sent req src 1.1.1.2 001f.6c95.66d0,
Jul 1 01:16:35.072 GMT+8: IP: s=1.1.1.2 (local), d=1.1.1.1 (Vlan70), len 100, encapsulation failed
Jul 1 01:16:35.072 GMT+8: ICMP type=8, code=0.
Jul 1 01:16:37.072 GMT+8: IP: tableid=0, s=1.1.1.2 (local), d=1.1.1.1 (Vlan70), routed via RIB
Jul 1 01:16:37.072 GMT+8: IP: s=1.1.1.2 (local), d=1.1.1.1 (Vlan70), len 100, sending
Jul 1 01:16:37.072 GMT+8: ICMP type=8, code=0
smothuku Wed, 07/01/2009 - 01:40
  • Silver, 250 points or more
Hi ,
instead of using fast ethernet ports as access port on both routers use them as trunk prot and allow only vlan 70 through that port.Check the ping response after making those ports as trunk.
satish
wandering_997 Thu, 07/02/2009 - 18:49
ping 1.1.1.2 source 1.1.1.3
ping 1.1.1.3 source 1.1.1.2
The source IP address must not be 1.1.1.1, because 1.1.1.1 is considered as themselves on both side.
Then you can figure out whether the layer 3 are ok.
xiachen Thu, 07/02/2009 - 22:11
  • Cisco Employee,
It is IP address subnet mismatch ! you use 1.1.10.0/24 on one router, but use 1.1.1.0/24 on the other router.
chinkevi_2 Thu, 07/02/2009 - 22:58
are you using ios emulator like dynamips?
or is the x-over cable dodgy?
Giuseppe Larosa Fri, 07/03/2009 - 13:25
  • Hall of Fame,
    Founding Member
Hello Alphonse,
the involved physical ports are on some form of etherswitch module.
The debug commands show that SVI vlan 70 is considered up/up but there is no L2 counterpart and so the encapsulation fails.
Now, in a real stand-alone switch using
switchport
switchport mode access
is enough to have the L2 vlan 70 created automatically (in newer releases that don't use vlan database).
To understand if the L2 Vlan70 really exist do
sh spanning-tree vlan 70
you may need to create explicitly the vlan before using.
if you have partner access see the following:
http://www.cisco.com/en/US/partner/docs/ios/12_4/interface/configuration/guide/h1636nm.html#wp1092154
it says to use the vlan database mode to create the L2 vlan object
enable
2. vlan database
3. vlan vlan-id [are hops] [backupcrf mode] [bridge type | number] [media type] [mtu mtu-size] [name vlan-name] [parent parent-vlan-id] [ring ring-number] [said sa-id-value] [state {suspend | active}] [stp type type] [tb-vlan1 tb-vlan1-id] [tb-vlan2 tb-vlan2-id]
4. no vlan vlan-id
5. exit
So this can be the issue here.
We are so used with newer switches and their ability to create vlans on demand.
Why vlan70 is up/up is another question
Hope to help
Giuseppe
wandering_997 Fri, 07/03/2009 - 17:22
Would you like to post the whole output below ? RISSGP0114 and RISSGP0115
show int f0/1/2
show int vlan 70
show arp | include 1.1.1.
show mac- | include
Wandering
kishan1984 Fri, 07/03/2009 - 11:38
In debug output it is showing encapsulation failed,so kindly check it first.
kishan1984 Fri, 07/03/2009 - 11:47
One more thing that type only "switchport" command under both routers fast eth interfaces.
