Two Native VLANs in One WiSM
Jun 30th, 2009
I have 2x6509 each with a WISM module running 5.2.178, now i wanted to design high availability,
Assuming WiSM in Coreswitch-1 has A1 and B1 sub controllers and Coreswitch-2 has A2 and B2 as sub controllers, I want to use A1 and B1 as one one Mobility group and A2 and B2 as another mobility group where acting as 2 different networks, with LWAP's getting different IP's, in such cases i should be running 2 different native vlans per WiSM Module.
Is this design technically right? what are the pros and cons to it?
I plan to run a seperate guest/video/voice WIFI network it it works.
Thank you in advance
dancampb Tue, 06/30/2009 - 05:53
That should be fine but really the native VLAN will have nothing to do with your design. Keep in mind all a native VLAN is on a 802.1q trunk is the VLAN which the packets in this VLAN do not get a 802.1q tag added to them.
jagebauer Tue, 07/28/2009 - 23:28
we make it like that:
create two AP-Manger Interfaces L3/L2 on 6500er....WLC1+WLC3 have configured Ap Manager Ip Adress from VLAN AP Manager1 and WLC2+WLC4 have configured AP Manager Ip Adress from VLAN AP Manger 2
Some APs are assigned to Vlan 1 and the others to vlan 2.....so you can configure two WLCS for High availability for each AP Group....
