Cisco AP1231G as WGB - %DOT11-4-CANT_ASSOC error message
Jun 30th, 2009
I have a Cisco AP1231G with autonomous IOS running in WorkGroup Bridge (WGB) mode.
However I can't get the device to associate with the root AP; which is a non-Cisco AP, and get the following error message.
%DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: WPAIE Invalid unicast suite count: 2
I've scanned Cisco documentation and run searches but I cannot find a doc that explains the cause of this error.
config extract below from Cisco WGB:
dot11 ssid TEST
authentication open
authentication key-management wpa
infrastructure-ssid
wpa-psk ascii 0 MY-PSK
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid TEST
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
power local cck 50
station-role workgroup-bridge
rts threshold 2312
l2-filter bridge-group-acl
bridge-group 1
dancampb Tue, 06/30/2009 - 05:54
  • Cisco Employee,
Bridging and WGB for the most part is not part of the 802.11 standards. Each vendor may do it a little different. What you probably want to try is to set this AP as a universal WGB. This mode the AP looks more like a client to the AP instead of a WGB.
dazza Tue, 06/30/2009 - 06:01
I can't configure
'station-role workgroup-bridge universal ...'
on the current IOS 12.3(8)JEA so I'll download a later IOS release to see if lets me set that parameter
dazza Wed, 07/01/2009 - 03:52
WGB universal mode does not appear to be supported on Cisco AP1231G even using the latest IOS image 123-8.JEC3 for that model.
Is that the case?
The Configuration Guide for 12.3(8)JEC suggests it is available for the 1200
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_10b_JA/configuration/guide/scg12410b-chap6-radio.html#wp1178578
BUT....previous IOS config guides (12.3(8)JEB) for the 1200 say that universal WGB mode is NOT supported on 1200
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_3g_JA/configuration/guide/s43rf.html#wp1178578
So...is universal mode supposed to be supported on the 1231 model or is the latest IOS documentation incorrect?
