Migrate CCM 4.1.3 to CUCM 7.x on new hardware
Answered Question
Jun 30th, 2009
Can someone point me in the right direction for instructions regarding a full migration of an existing CCM 4.1.3 installation, over to a CUCM 7.x platform? (New hardware). I can only seem to find upgrade instruction on same hardware.
All help appreciated!
Ole Vik
Correct Answer by Jaime Valencia about 7 years 7 months ago
It's exactly the same.
Old or new HW you wipe out everything the server had before and use the DMA tar file.
The extra step is to make sure to rehost your licenses to the new MAC sending them to licensing@cisco.com and explaining you're changing HW.
java
if this helps, please rate
Overall Rating: 4 (1 ratings)
Correct Answer
Jaime Valencia Tue, 06/30/2009 - 08:25
java
