Distant OSPF neighbors
Answered Question
Jun 30th, 2009
I have two routers connected via VSAT, and between then there is many hops of the VSAT equipments that block OSPF hellos.
I have the solution to use tunnels, is there any other way to specify the IP of the neighbor?
Omar
Overall Rating: 5 (1 ratings)
omar.elmohri Tue, 06/30/2009 - 06:46
In NBMA, I can specify the neighbor command, is this sufficient?
omar.elmohri Tue, 06/30/2009 - 07:42
Not exactly, I want to avoid using the GRE tunnel. and make adjacencies with distant routers.
Correct Answer
AKAIK - that is not possible. If you are passing from 1 network to another via an IP network in the middle, you will have to encapsulate the multicast hello's. or if the IP network in the middle is already running OSPF - then create a virtual link and piggy back it.
