RTMT 8.1.0.0 install / uninstall / Reinstall = error ?
Jun 30th, 2009
we do the follow tasks :
- installation of RTMT 8.1.0.0 taken from CCM 7.1.2a.
- uninstallation of RTMT 8.1.0.0 .
- reinstallation of RTMT 8.1.0.0 : we have got an error:
Error
You have a RTMT of version 8.1.0.0 already installed.
you are not allowed to install more than one copy of RTMT of same version on same machine.
RTMT exists at location : NULL
Please uninstall the previous installation and try again.
Press EXIT to quit installation.
Thank you for your help.
./DEWA
j.sillers Sun, 07/12/2009 - 10:29
I am getting the exact same message. I un-installed version of RTMT from UCM 7, then tried installing UC 7 to get the UC tabs. But now neither will install because:
Why is it located in NULL?? I have seen this message before when the system has RTMT installed under another user but then there is a path designated so I simply use that version.
I tried killing every registry entry I could find for RTMT or Servicability or Real Time Monitoring, but it still gives me this message. There is nothgin in control panel to uninstall.
Beth Verish Mon, 10/12/2009 - 09:12
I am in the same situation, uninstalled and getting error message when trying to reinstall. Any resolution? Thanks
Beth Verish Wed, 10/28/2009 - 13:57
I got this fixed, thanks Dwight Bullard at TAC.
Go to C:/Program Files/ Zero G Registry open the file ".com.zerog.registry.xml" in a text editor.
Then delete the entries corresponding rtmt 8.1 (make sure you delete the block of xml tag, and not just the lines)
E.g. remove the below entries
And a corresponding entry in the tag
