L2TP split-dns
wstuart
Configured L2TP with split-tunnel and split-dns configured. Using the built-in L2TP on XP, Vista and Windows 7.
The client seems to be configuring itself correctly, however, when I look up a name that appears in both outside and inside DNS, it seems to use the outside name.
Anyone have a fix?
wong34539
Level 6
Level 6
Determines whether the connection entry is using splitDNS, which can direct packets in clear text over the Internet to domains served through an external DNS or through an IPSec tunnel to domains served by a corporate DNS.
Information on how to configure the Microsoft L2TP client is foundhere:
http://technet.microsoft.com/hi-in/windowsserver/2000/default(en-us).aspx
